Part Number: TRF1305B1
Other Parts Discussed in Thread: TRF1305
HI,
When I am referring to the data sheet in PCB recommendation section.
the input and output to the IC is routed as Coplanar single ended 50 OHM, after resistor it has been routed as coplanar 100 OHM.
In my design input to the ic is from a photo diode which has PD+ and PD- signals.
Please clarify the following points:
whether it is Coplanar or Non coplanar. What is the impedance that should follow for routing.
