OPA2227-EP: OPA2227-EP
Part Number: OPA2227-EP
Hi can anyone recommend an dual opamp that has better characteristics than this. the OPA2120 look better but the datasheet does not described the -55c characteristic for noise etc. can anyone help me
regards
Ross
  • Hi Ross,
    OPA2227-EP is enhanced op amp product, which is tailored for military, aerospace, and high-reliability industrial uses, and the temperature operating range is rated from -55C to +125C. The product is qualified and process is certified to have the rating (it also costs more due to paper work and certification etc..).
    https://www.ti.com/lit/rr/sprk052/sprk052.pdf?ts=1750612394350
    Which OPA2120 are you referring to? OPA2210 op amp? Typical op amps are industrial grade (-40C to +125C) and it does not guarantee to operate -55C to +125. However, it does not mean it is unable to operate at -55C. You have to validate on your own and verify that it will meet for your requirements and application.
    If your requirements are specified between -55C to +125C, then you have to use certified op amps. The selections in -EP or other higher certified op amps are limited.
    If you have other questions, please let me know.
    Raymond
