Part Number: OPA355
Other Parts Discussed in Thread: TINA-TI, OPA838, THS4551
I am planning to design front end for ADC .. with low noise
if fC of filter is 10MHz and Input signal frequency is 500KHz then
So intial stage is Non inverting amplifier - so
- To eliminate error due to offset shall i use Capacitor at input ? and can u recommend any document to select that capacitor..
- If my gain is 10 then should i chose GBW of atleast 10*500KHz or 10*10MHz ?
- To eliminate noise i want to keep capacitor in feed back or want to use RC at output of Non inverting op amp & Shall i limit op amp BW to 500KHz or 10MHz ?
- I want to use 4th order filter , will filter eliminate noise due to Non inverting amplifier? & will filter also generate noise ? if generates , cascaded nxt stage can eliminate the previous noise?
- Please suggest op amp for my requirements for Non inverting amplifier and Filter designing.
