Part Number: OPA817
Can you send me a spice model for this op-amp? I want to put it into HFSS electronic desktop to simulate it in conjunction with an HFSS 3D simulation.
Part Number: OPA817
Hi Daniel,
I attached the .LIB for this device. I am not sure if this is the type of file you would need for this type of simulator, so I hope this helps.
Ignacio
The file is good, but here are several parts in the library file you sent and I'm wondering what the differences are between them. These are the ones I found:
VCM_CLAMP_OPA817
VNSE_OPA817
VOW_DRIFT_OPA817
OPA817
Dan
Hi Dan,
These are all subcircuits in our models that we use to model different specs. There is not much that we can change from that aspect as most amplifier models will have these subcircuits and use this architecture.
Ignacio
Hi Daniel,
The subcircuits you highlighted are used to replicate different specs in our device. The subcircuits are referenced in different portions of the netlist so I am not sure if you could remove them without affecting other portions of the circuit.
Ignacio
