TAS67534-Q1: 1L Modulation
Part Number: TAS67534-Q1
Other Parts Discussed in Thread: TAS6684-Q1,
Hi TI Team,
What is the advantage of 1L (single-inductor) modulation in the TAS67534-Q1 compared to the  two-inductor solution used in the TAS6684-Q1?
Thank you.
  • Hi Amirthathaarani,
    There are three big advantage you can get through using TI 1L modulation IC (TAS67534-Q1).
    1. BOM cost reduction
    Since there is only single inductor on output side, you can reduce one inductor, and get cost benefit.
    2. PCB size reduction
    Since there is only single inductor on output side, you can make pcb size more smaller.
    3. Increasing the efficiency
    Since the 1L modulation make IC's switching loss lowering, you can get more higher efficiency.
    Liam Ryu
