Part Number: OPA2683
Other Parts Discussed in Thread: THS4551, OPA2836, OPA836
Hello TI Team,
I am looking for a high-speed, unity-gain-stable amplifier to use as a buffer stage immediately before the input of my THS4551 fully differential amplifier (FDA).
My application requirements are:
Signal: single ended Pulse waveform, approximately 0–2.8 V steps waveforms any voltage in between .
Frequency: 7.5–10 MHz.
Rising slew rate: 80 V/µs.
Falling slew rate: 45 V/µs.
Configuration: Unity-gain voltage follower.
Priority: High bandwidth, fast settling time, low distortion and stable operation when driving the THS4551 input.
Purpose: Accurate characterisation of a high-speed 14 bit ADC.
Could you please recommend a suitable TI amplifier and clarify the following?
What minimum gain-bandwidth product, slew rate and settling time should I target?
How can I verify that the buffer settles adequately before the THS4551 input under my pulse conditions?
What output-drive capability and capacitive-load stability considerations should I account for?
Would a wideband voltage-feedback amplifier or another amplifier topology be more suitable for this application?
Are there any recommended reference circuits or evaluation modules for this configuration?
I would appreciate a suitable part number and guidance on the calculations required to verify the amplifier's performance.
Thank you for your support.
Best regards
