Part Number: THS4551
Other Parts Discussed in Thread: TINA-TI
Hello TI Team,
I am using the THS4551 in an RGT package
Application requirements:
Differential output: 2 Vpp.
Input signal: Square-wave/DC levels varying from 0.2 V to 2.8 V. (Supply is single supply 5V)
Intended gain: 0.7 V/V, but I am unable to achieve the expected gain in hardware.
I would like to understand whether I should first validate the circuit at unity gain or directly test it at a gain of 0.7 V/V.
Could you please guide me on the following?
All measurement tell in hardware and TINA TI
DC performance: How can I measure gain accuracy, gain linearity, input offset voltage, and offset variation in hardware and TINA-TI?
Gain configuration: For a gain of 0.7 V/V, how should I select the feedback resistor (Rf) and gain resistor (Rg)? Should I use equal resistor values or adjust their ratio? What could cause the measured gain to differ from the theoretical value?
AC performance: How can I measure the −3 dB bandwidth, gain flatness, noise density, and distortion?
Stability analysis: How can I evaluate loop stability, gain margin, and phase margin in TINA-TI? Would adding a 1 pF feedback capacitor provide any benefit, and how should I determine its appropriate value?
Transient analysis: How can I evaluate stability, overshoot/peaking, settling time, slew rate, and step response using TINA-TI? What hardware measurements would you recommend?
Large-signal performance: Since my input is a square wave with levels from 0.2 V to 2.8 V, how should I evaluate large-signal bandwidth and slew-rate limitations? I understand that small-signal bandwidth alone may not adequately characterize this response.
Output swing: How should I verify that the THS4551 can achieve the required 2 Vpp differential output without clipping or distortion under my supply, output common-mode voltage, and load conditions?
I would appreciate a step-by-step procedure for performing these simulations and hardware measurements, including the recommended test conditions and important parameters to consider.
Please let me know if additional circuit details are required.
Thank you.
