Part Number: OPA340
The customer has noticed that there are many instances where the waveforms at the test points of the boards are distorted or have excessively high amplitudes.
1. When sending signals to two motherboards (J2 - alternating current electric field) using a signal generator for analysis and testing, the same abnormal problem was indeed reproduced. 2. Then, the circuit was gradually analyzed, and it was found that the signal input from J2 to U14 was normal. After passing through U14 (OPA340NA/250) amplifier, waveform spikes and amplitude abnormalities occurred. After replacing the U14 chip for verification, it was confirmed that the fault was in the U14 amplifier. 3. Comparison before and after replacing U14
Please help me check if there are any flaws in the schematic design.
