Other Parts Discussed in Thread: DRV401
Dear All
DRV401 IC sensor signal conditioning IC for closed loop magnetic current sensing is designed to work with Vacuumschmelze (VAC) passive current sensors. I am trying to make it work with VAC part number 4645X050. The IC datasheet mentions the normal operational frequency range to be between 250kHz to 550kHz. What I get in my circuit is approximately 25kHz. This leads me to believe that the circuit is not working properly. Information in the datasheet does not provide any clues nor have I found any other source which may shed some light on the issue.
Any help/suggestions/literature would be greatly appreciated.
Thanks in advance.
i.k.
