Other Parts Discussed in Thread: TLC071
I designed a filter using TLC071 because it is supposed to work with a single power supply , but the op amp just works when connected to two power supply. Is there anything I am missing?
Elaine,
Make sure that you are operating the TLC071 within the specified input and output operating ranges; VICR, VOH, VOL, etc. Also, be sure that if you are using a PowerPad package that the power pad is connected to the same potential as the GND pin.
Regards, Thomas
PA - Linear Applications Engineering
