Other Parts Discussed in Thread: LMV7272
I may have misread the LMV7272 datasheet, but I can't find the X1, X2 and X3 dimensions of the CSBGA package. Could you help me on this matter?
Thibault
Thibault
Hi Thibault,
I apologize for the delay... I just checked the datasheet on the web and it has been updated with the Max/Min package dimensions. The value that I gave you before was a typical. Please refer to the LMV7272 datasheet for the maximum package dimensions.
Sergio
Hi Sergio,
Thank you for your reply. I checked the datasheet before asking you again, but only the first page, where revision is "August 2012", hence I didn't went to the package page. Sorry for that.
I'm refering to the http://www.ti.com/lit/ds/symlink/lmv7272.pdf now, where there is indeed min & max value. I may be a little strict, but the package drawing at page 26 refers to X1, X2, X3. Then, at the bottom of this page, there is X and Y (max= 1.57 mm, min= 1.469 mm). I think that should be X1 and X2, isn't it? :) X3 is also not specified.
Thibault
Hi Thibault,
The team is aware of the missing parameter in the package drawing and the datasheet will be updated soon. In the mean time, just to give you an idea, the maximum height for the YZR-8 package is 0.675mm. It might be rounded up to 0.68mm later in the datasheet. Once updated, please go by what the datasheet says.
Sergio
Hi Thibault,
Thanks for your feedback in this thread. I'd like to let you know that the LMV7272 package information in the datasheet has been corrected and the latest document on the web shows the package dimensions in question.
Kind regards,
Sergio
