Other Parts Discussed in Thread: THS4513-SP, THS4513
We are looking at using the THS4513-SP amplifier with a 20dB gain. However, I'm not exactly sure exactly how to interface to it.
We want to use a single supply, with Vs+ =3.3V and Vs- =GND. I don't think the THS4513 is a rail to rail device, so how close to the rails can I expect the output signal to swing? We need to use 0.75V-1.0V as the Common Mode voltage. Are there any impacts on performance?
Also, what is the proper way to interface the input of the amplifier to the differential output of a Vectron TFS35A SAW filter?
http://www.vectron.com/products/saw/pdf_saw/TFS35A.pdf
If we don't have a supply voltage present, what is the allowable input voltage? Similarly, when in power-down mode, what is the allowable input voltage?
Thanks a lot,
J
