Other Parts Discussed in Thread: LM321, OPA209, OPA140
need the same OP AMP lik LM321 but with with lower V offset of 0.5mV, in the same shape
Hello Eli,
What is your supply voltage?...that will greatly influence your choices.
If you need the full 32V, you are out of luck as the LM321 has a "321" SOT pinout (typical with the low voltage parts) and the other high voltage SOT's (OPA140 and OPA209) are in a "standard" SOT pin out.
The supply needs to get to 12V before more direct-replacement options show up.
