Other Parts Discussed in Thread: LMP7721, LMC6482, LMC6041, LMC6081
I want to use the LMP7721 to amplify a 10nA to 50nA input current. In order to get a corresponding 1 to 5V output range, I need a 100MOhm feedback resistor. Supposing to use an almost perfect PCB (as its EVAL board from TI, for example), how high can I hope to go in bandwidth ?
Things go better if I accept to have a smaller feedback resistor, but in that case I will need a second (voltage) amplification stage to go to the desired output range. Will this be a suitable solution or I will add too noise to the output signal ?
Many thanks in advance for your considerations,
best regards
Marco Sartore
