OPA454 feedback capacitor
Hi.
How to calculate the value of feedback capacitor Cf in the datasheet in figure 60 (External outputs transistors boost output current greater than 1A)?
Thank's
  • Dario,
    This may not be an entirely satisfying  answer but this capacitor value Cf is probably best determined by experimentation. The optimum value will depend on many factors including closed-loop gain (R1, R2), transistor selection, load characteristics (resistive/capacitive, etc.) and output current range.
    I suggest that you start with approximately 500pF. Use the response to a small input step voltage of 50mV, or so, to test the circuit with your actual operating conditions. Focus attention on the response at the lowest expected current levels. A response of greater than approximately 20% overshoot is tending toward instability and needs a higher capacitor value.
    Regards, Bruce.
