Other Parts Discussed in Thread: INA138
please help check if no load then how calculate Vo about INA138?
thanks
thanks
Hi Ou,
Thank you for your question on INA138. The load resistor is required to be connected for proper operation of the INA138...here is a diagram showing the fundamental operation of the INA138. I have highlighted the signal current path for you with a red arrow.
Leaving the load resistor off with output left floating (or driving a very high impedance) will result in abnormally large gain and the output will be stuck at it's maximum limit determined either by the power supply voltage or common mode voltage.
Ed Mullins
Applications Manager
AIP - Sensing Products
