Other Parts Discussed in Thread: LF411
I have downloaded the Pspice model for the LF411C and created its symbol. When I try to simulate the circuit, I get the error saying that Pin1 through Pin5 are
not in the template. The subckt has the pins from 1 through 5 and without knowing which pins correspond to which pins in the datasheet, the simulation will
fail. I think that's what's happening. This is a 7-pin device. I thought that the two missing pins are the power pins., so I assigned the pins
and added twp power pins in the symbol. It didn't work. I think that the "Order" in the part property is messed up. I don't want to spend time to try assingning
different ways. Does anyone have the correct part property that correspond to the subckt for LF411C?
Thank you,
