Other Parts Discussed in Thread: DDC112
Hello Bonnie,
I read your articles in EDN all the time and have a few questions concerning the IVC102 Switched Integrator TIA.
Any information you could forward concerning the operation and noise analysis of this device would be helpful.
My application is attempting to use this device with an unbiased InGaAs photodetector.
This configuration seems to offer the best noise performance at low signal levels (bias voltage induced dark current is gone).
Have you considered or worked with anyone using the device in this configuration?
The only draw back I can see is the output noise hit because of the higher input capacitance.
Here are my more general questions on the device;
The 10 nV/rt(Hz) noise voltage given on the data sheet… is it input referred or output?
The temperature performance of this device is not specified in the data sheet…can you offer any other sources to help in determining the performance of this device over temp?
I see a curve for the input bias current over temp…is this for both the inverting & non inverting nodes? I’m also assuming this will induce a temperature dependent output voltage swing is this the case?
The device seems to be specified at +/-15V any thoughts on my trying +/-5V?
Again any insight you could offer would be greatly appreciated.
Robert.
