IVC102 pcb
Other Parts Discussed in Thread: LMP7715
Dear community,
After very close examination and study of IVC102's datasheet I have made two versions of PCB layout.
I have attached pdf files of each in zip. Blue is the bottom, red is the top side.
Version one uses lmp7715 as a drive for a guard ring at 0 Volts.
Version 2 uses no drive but the guard ring is the analog ground. Version 2 also has a keepout region for the sensitive pins.
Which do you believe is better?
I can also upload eagle files and gerber files if requested.
Thank you a priori.
ivc.zip
