Other Parts Discussed in Thread: INA333
I want to use a member of the INA210-INA214 family in one of my new projects.
i want to measure current with a shunt drops of 10mV full-scale (datasheet)
Lets take the 213, typical +/-5uV but the max. is +/-100uV
i want to measure high current AND LOW current with a range of 1000:1 (10 bit AD converter(1024)) meaning the LSB is 10uV (x GAIN)
now 10uV is above the typical 5uV but way below the max. 100uV, meaning a reading of 20 could mean 300uV (+100uV offset) or 100uV (-100uV offset), a huge error.
(always at least a 1% error full scale and much more with lower voltages +100%)
Am i doing something wrong?
Is the offset voltage constant on one IC initial and over time (constant temp), and if so is there an easy way to correct this?
