Other Parts Discussed in Thread: THS4521, TINA-TI
looking for differential AMP. with gain =100,high SNR, low distortion , 1HZ-1KHZ, single supply, 3.3V.
Hi Eli,
Here is a Parametric Table / Selection guide:
Here is a 40dB gain design using THS4521 with 3.3V single supply (Output CM set to mid-rail) which far exceeds your bandwidth needs.
TINA-TI file:
7713.THS4521 Av=40dB E2E Hooman 10_29_14.TSC
Noise is also modelled in TINA-TI, but for distortion you must consult the datasheet.
Hooman
