Other Parts Discussed in Thread: PGA4311
Can I know about the Thermal resistance values and Maximum Power Dissipation for part# PGA4311U ?
Maruthi
Maruthi
Hello Maruthi,
The PGA4311 is a low-power device which is only used to drive line-level audio signals into relatively high-impedance loads. Its thermal resistance and maximum power dissipation should not be a concern, since it will be a very small contributor to the overall temperature of the PCB and surrounding air. Do you anticipate that your circuit will be very sensitive to small thermal variations?
Ian Williams
Linear Applications Engineer
Precision Analog - Op Amps
