Very high speed Log Amplifiers
Other Parts Discussed in Thread: LOG114
My objective :
converting laser pulses from photo diode ranging from 10nA - 100mA (70dB dynamic range of incident power) to digital format, for measuring pulse width exactly
pulse width 10ns and repeating at a rate of 20us
i have seen pretty encouraging application notes for a wide dynamic range TIA requirements of about 100dB input power , but my doubt is how fast they can be ?, as the normal diodes cant be very fast as 2ns(considering my photo diode rise time), how about a Ghz BJT as feedback element or a schottky diode in feedback( i did not find people trying such), i do have found few integrated designs like LOG114 but i did not find a high freq log amplifier modules being available, is it possible to sense ns pulses using log amplifiers ?
  • Hello Daram,
    Thanks for your interest in TI parts. I don't have an answer for your question at this time. I will refer your question to our transimpedance expert and see if we can find a solution for you.
    Loren
  • Daram,
    We don't have any high-speed log-amps other than the one you already found. I am not sure about using a schottky diode in the feedback but using a discrete high-speed BJT with an fT in the GHz region along with one of the very high speed opamps from our portfolio is certainly something worth trying. Our high-speed amplifier team does not have any product offerings when it comes to discrete transistors however if you find a transistor you like you could simulate it in TINA to see if you can achieve the desired performance.
    -Samir
