Other Parts Discussed in Thread: DRV425
[ DRV425 ] Current Sensing for BLDC Motor Current
My customer has been looking for alternative solutions of isolated current sensor from Allegro for their BLDC motor current sensing.
ACS723: High Accuracy, Galvanically Isolated Current Sensor IC
www.allegromicro.com/.../ACS723.aspx
As far as I check the solution from TI, DRV425 could be one of suggestion for my customer.
However, it's sill not clear for my that the advantage/disadvantage over ACS723.
On top of that, I don't think my customer can use "drilled busbar" which is described in the datasheet, because they use standard PCB and wire harness between board and motor.
Can you help me to understand your solution more precisely?
Thank you for your help in advance.
Ken
