Other Parts Discussed in Thread: TLE2142A, XTR116, XTR110, XTR111, XTR300, TL082, TL084, OPA192, TINA-TI
Hi, Team.
I had been asked opamp and Current Output Equation (I load) by Mitsubishi which is industrial company in Japan.
I'm supposed to suggest good opamp for its schematic and tell them I load equation.
I think that TLE2142A can be working and its offset voltage is lower than their opamp
*currently ADI Opamp is the device what customer has used
(Datasheet is www.analog.com/.../ADTL082_084.pdf)
[could you check the their schematic ?]
the following circuit's I load should be changed by changing RL.
they want to know equation as well the opamp which is better than ADI.
is below equation correct ?
on top of that,
I think that XTR116 is good device for their purpose, isn't it ?
