Customer uses a uni-gain buffer to do a voltage sensing with the baterry cell.
When the R993 resistor is removed(it means the positive terminal of the LMV321 is floating), the output voltage of LMV321(U990) will output 4V. Why? How to prevent this by effective way? any other good OPA recommended to improve it?
We tried to add a Resistor 10M-Ohm connected in between positive terminal of LMV321 and grounding. it can reduce the output voltage of LMV321 to 0.8V, however, it is an efficiency killer that customer doesn't prefer to do it. Thanks.
Brian
Brian
