Other Parts Discussed in Thread: TLV521, TLV3691, LPV7215, TLV3701
Dear Sir
May I know how to use TLV521 to do a comparator ??
Could you kindly help to provide the reference schematic ??
Hello Kai,
Yes. The TLV521 can be used as a comparator, but we generally discourage the use of an op-amp as a comparator.
You would connect the op-amp the same as the comparator. Only difference is that the op-amp does not need a pull-up resistor on the output.
If you do use an op-amp as a comparator, you really should add hysteresis:
https://e2e.ti.com/blogs_/archives/b/thesignal/archive/2013/01/28/comparators-what-s-all-the-chatter
You would really be better off using a true micro-power comparator. We have several comparators that are lower power than using the TLV521.
I suggest:
TLV3691
LPV7215
TLV3701
