Other Parts Discussed in Thread: OPA659EVM, LMH5401, ADC12J4000, OPA659
We are needing a unity gain buffer for a high-speed open-circuit voltage decay measurement system. The unity gain buffer will take as its input the open-circuit voltage of a solar cell device. We are looking at the OPA659EVM to fulfill this purpose. However, the OPA659EVM has its non-inverting input pulled down with a 50-ohm resistor. This may not work for our intended purposes since the input voltage signal must be as close to an open-circuit condition as possible. Would removing the 50-ohm resistor cause any issues with the unity gain buffer stage?
In more detail, the unity gain buffer's single-ended output is fed to the single-ended input of a LMH5401, which is then sent as a differential signal to the inputs of a high-speed ADC (the ADC12J4000).
Thank you for your assistance in this matter.
-Alex
