I need a low freq single supply 15v opamp that has low input offset and is temperature stable from 29 degrees f to 125 degrees f. Low cost please. It will be used as a trans-impedance amp for a photodiode. Any suggestions? Thank you.
Hi Alvin,
When I review your requirements for a low drift, low cost, op amp I believe the following two products should do what you need:
Let me know your thoughts about them relative to your transimpedance application. If one or the other isn't what you had in mind, we can explore some other possibilities.
Regards, Thomas
PA - Linear Applications Engineering
Thank you Thomas for your quick reply. I will study what you have sent me. From my brief look it looks very good. Thanks again. ALvin..
