Other Parts Discussed in Thread: LMV710-N, LMV712-N, LMV881
Hi All,
Customer has below two requirement for operational amplifier
1) When power supply voltage is below the minimum working voltage, output saturated to ground / VEE.
2) No protection diodes between inverting and non-inverting terminal.
This two requirement is not like common parameter like BW, noise, supply voltage, etc. Then how to make a quick filter of all TI OP for this two feature.
I know some operation amplifier has integrated back to back diode in the input pin, some not, so is there any filter option in TI OP product folder, or that we can open select it based on experience? It is not possible to open every datasheet to check the spec.
Thank you very much.
Best Regards
Charles Zhang
