Is there any device with 8 channel differential amps.Required for adc interface to 28335 dsc.
I am not aware of any 8 channel op amps. But you could use two 4 channel op amps to give you the required 8 channels.
Another option would be to use a multiplexer such as the MUX36D08 to switch between channels.
Thank you,
Tim Claycomb
Thank you.
How about TLC274X2?
Offset is high.
Temp.of operation 70 deg C.
Mux option looks attractive.
Thank you.
Soundararajan K
The TLC274x2 is an obsolete device meaning it is not offered any more.
If you provide the specifications you are looking for in a device (power supply, offset, quiescent current, etc.) I can recommend a device for you.
Thank you,
Tim Claycomb
