May I know if INA226 used to AC line monitor? Such as MCP39F501 solution as below.
Thanks your help.
Eric
Thanks your help.
Eric
Hi Eric,
Would you be able to provide us with more details as to your application?
The INA226 is intended for the measurement of DC units. For a AC Mains power monitor, capable of simultaneously measure current and voltage, no.
For applications where the mains voltage is rectified, such as a switch mode power supply or a motor drive, it could be used for measurements after the rectifier. This application note shows some design changes, allowing the device to operate at higher than VCC supply voltages.
