OPA564: DWP Package Specifications
Part Number: OPA564
The datasheet for this part on page 24 under Bottom-Side PowerPAD Assembly Process in items 2 and 3 indicate there is an "attached thermal land pattern mechanical drawing" that shows the top side etch pattern and recommended number of thermal vias. The only information close to this is page 33 in the PDF, "DWP mechanical data". This page shows the physical outline for the part and thermal pad, but gives no recommended top side etch pattern, number, or location of thermal vias. I contacted support@ti.com and they provided the document ‘PowerPad Made Easy’, and I also downloaded the Ultra Librarian .bxl files associated with this part. The patterns provided in the two documents differ substantially, including number and location of vias, thermal land size/spacing from pins, pin pad dimensions, as well as others.
Could you provide guidance as to the recommended layout for this part as well as the discrepancy between the documents?
Thanks!
Zeke Gustafson
