Other Parts Discussed in Thread: THS4222
I am looking to design an active filter system for the THS4222. I would like to provide it with a positive and negative supply.
I am looking at different bench-top power supply units. I am considering this unit:
http://www.extech.com/instruments/resources/datasheets/382203_13_22_25data.pdf
Would I be able to generate a negative voltage by switching the + and - outputs? I figure that I would use the +5V fixed supply for the positive rail, and then use the adjustable output with switched terminals to generate the -5V supply for the negative rail.
Do you have any insight on this? Is there another power supply you recommend?
Alex
