LMP91000: 请选择网省
Part Number: LMP91000
Hi!
Customer problems: when using LMP91000 environment for testing their correlation with alpha values in 0.7 to 0.8, oneself use discrete device structures, alpha value is 0.8 to 0.9, the think manufacturer, please help to analysis what causes.
Looking forward to reply,Thanks!
  • Jason,
    A member of our support team will get back to you shortly. Thanks
    Will
  • Hi Jason,
    Could you please better explain the issue? Could you provide some schematics and the values of the configuration registers?
    Thanks in advance.
    Carmine
  • Hi!
    About LMP91000 use, client configuration is as follows:
    #define LMP_REG2_UNLOCK 0x00 //LMP寄存器2中的数据0x00
    #defineLMP_REG2_LOCK 0x00 //LMP寄存器2中的数据0x01
    #defineLMP_REG3_DATA 0x1C //LMP寄存器3中的数据0x0E
    #defineLMP_REG4_DATA 0x80 //LMP寄存器4中的数据0xB0
    #define LMP_REG5_DATA 0x03 //LMP寄存器5中的数据0x07/03
    #define LMP1_REG2_UNLOCK 0x00 //LMP寄存器2中的数据0x00
    #define LMP1_REG2_LOCK 0x00 //LMP寄存器2中的数据0x01
    #defineLMP1_REG3_DATA 0x1C //LMP寄存器3中的数据0x0E
    #defineLMP1_REG4_DATA 0x80 //LMP寄存器4中的数据0xB0
    #define LMP1_REG5_DATA 0x03 //LMP寄存器5中的数据0x07/03
    #define LMP2_REG2_UNLOCK 0x00 //LMP寄存器2中的数据0x00
    #defineLMP2_REG2_LOCK 0x00 //LMP寄存器2中的数据0x01
    #defineLMP2_REG3_DATA 0x1C //LMP寄存器3中的数据0x0E
    #defineLMP2_REG4_DATA 0xC0 //LMP寄存器4中的数据0xB0
    #define LMP2_REG5_DATA 0x03 //LMP寄存器5中的数据0x07/03
    #define LMP3_REG2_UNLOCK 0x00 //LMP寄存器2中的数据0x00
    #define LMP3_REG2_LOCK 0x00 //LMP寄存器2中的数据0x01
    #defineLMP3_REG3_DATA 0x1C //LMP寄存器3中的数据0x0E
    #defineLMP3_REG4_DATA 0xC0 //LMP寄存器4中的数据0xB0
    #define LMP3_REG5_DATA 0x03 //LMP寄存器5中的数据0x07/03
  • Hi!
         Register configuration information received?
         Please help to reply quickly
  • #define LMP_REG2_UNLOCK 0x00 //LMP寄存器2中的数据0x00
