Part Number: DRV401
Dear Technical Support Team,
I'd like to use external differential amp with DRV401 instead of internal differential amp, so these pins can be open?
6 pin :Vout
7 pin:IA in2
8 pinj:IA in1
ttd
Part Number: DRV401
6 pin :Vout
7 pin:IA in2
8 pinj:IA in1
ttd
Hi ttd
I believe this is not possible but I will have one of our DRV experts to look at your question today.
Mayrim
Hello ttd,
You can bypass the output amplifier. If you are measuring higher frequencies >50KHz you may look at the CMRR of you external amplifier as the common mode of the Icomp pins can change abruptly during the compensation.
