INA219
Other Parts Discussed in Thread: INA219, TEST2
We build a board 2 INA219.
We are using ESP32 with python library (from here https://github.com/chrisb2/pi_ina219/blob/master/ina219.py. We are using on board 0.1 ohm shunt
Everything works fine on I2C, but the current and power output are always ZERO.
I checked step by step the library and regarding the current I saw that reading from registry is returning always zero. Below is some output with and without battery.
Any idea why we got ZERO amp?
Thx
ina219 loaded
[65, 68]
DEBUG:INA219: gain set to 0.04V
DEBUG:INA219: shunt ohms: 0.010, bus max volts: 16, shunt volts max: 0.04, max expected amps: 0.200A, bus ADC: 3, shunt ADC: 3
DEBUG:INA219: calibrate called with: bus max volts: 16V, max shunt volts: 0.04V, max expected amps: 0.200A
DEBUG:INA219: max possible current: 4.000A
DEBUG:INA219: max expected current: 0.200A
DEBUG:INA219: __CURRENT_LSB_FACTOR 32800 current_lsb: 6.250191e-05
DEBUG:INA219: current LSB: 6.250e-05 A/bit
DEBUG:INA219: power LSB: 1.250e-03 W/bit
DEBUG:INA219: max current before overflow: 2.0480A
DEBUG:INA219: max shunt voltage before overflow: 20.4800mV
DEBUG:INA219: calibration: 0xfffd (65533)
DEBUG:INA219: write register 0x05: 0xfffd 0b1111111111111101
DEBUG:INA219: configuration: 0x019f
DEBUG:INA219: write register 0x00: 0x019f 0b110011111
DEBUG:INA219: read register 0x02: 0x06ba 0b11010111010
Bus Voltage : 0.860 V
DEBUG:INA219: read register 0x04: 0x0000 0b0
DEBUG:INA219: _current_register: 0
Bus Current : 0.000 mA
DEBUG:INA219: read register 0x01: 0x0000 0b0
Supply Voltage : 0.860 V
DEBUG:INA219: read register 0x01: 0x-001 0bb1
Shunt voltage : -0.010 mV
DEBUG:INA219: read register 0x03: 0x0000 0b0
Power : 0.000 mW
WITH BATTERY
ina219 loaded
[65, 68]
Power : 0.000 mW
  • Hello Cata,
    We are currently looking into this problem. Could you please share a simple schematic and if this is a high or low-side application? Also, your code is saying the Rshunt is 0.01Ohms, is this correct?
    Sincerely,
    Peter Iliya
    Current Sense Applications
  • Hello Peter,
    Here are the schematics:
    drive.google.com/.../view
    and INAs soldered:
    Regarding the results below you can find a fresh set... I copy& paste a wrong test result. My apologies for this.
    TEST1 UART connected and NO battery and NO Solar MPPT
    INA addr 65
    DEBUG:INA219: gain set to 0.32V
    DEBUG:INA219: shunt ohms: 0.100, bus max volts: 32, shunt volts max: 0.32, max expected amps: 3.000A, bus ADC: 3, shunt ADC: 3
    DEBUG:INA219: calibrate called with: bus max volts: 32V, max shunt volts: 0.32V, max expected amps: 3.000A
    DEBUG:INA219: max possible current: 3.200A
    DEBUG:INA219: max expected current: 3.000A
    DEBUG:INA219: current LSB: 9.146e-05 A/bit
    DEBUG:INA219: power LSB: 1.829e-03 W/bit
    DEBUG:INA219: max current before overflow: 2.9970A
    DEBUG:INA219: max shunt voltage before overflow: 299.6981mV
    DEBUG:INA219: calibration: 0x117e (4478)
    DEBUG:INA219: write register 0x05: 0x117e 0b1000101111110
    DEBUG:INA219: configuration: 0x399f
    DEBUG:INA219: write register 0x00: 0x399f 0b11100110011111
    DEBUG:INA219: read register 0x02: 0x06b8 0b11010111000
    DEBUG:INA219: read register 0x02: 0x06da 0b11011011010
    DEBUG:INA219: read register 0x04: 0x-003 0bb11
    DEBUG:INA219: _current_register: -3
    Bus Current : -0.274 mA
    Supply Voltage : 0.876 V
    DEBUG:INA219: read register 0x02: 0x06e2 0b11011100010
    DEBUG:INA219: read register 0x01: 0x-002 0bb10
    Shunt voltage : -0.020 mV
    Power : 0.000 mW
    INA addr 68
    DEBUG:INA219: read register 0x02: 0x06d2 0b11011010010
    Bus Voltage : 0.872 V
    DEBUG:INA219: read register 0x04: 0x-001 0bb1
    DEBUG:INA219: _current_register: -1
    Bus Current : -0.091 mA
    Supply Voltage : 0.872 V
    Power : 0.000 mW
    >>>>>>>>>>>TEST2 UART and LipO 6600Mah Battery connected but NO Solar MPPT
    INA addr 65
    DEBUG:INA219: read register 0x02: 0x1ec2 0b1111011000010
    Bus Voltage : 3.936 V
    Supply Voltage : 3.936 V
    Power : 0.000 mW
    INA addr 68
    DEBUG:INA219: read register 0x02: 0x1eca 0b1111011001010
    Bus Voltage : 3.940 V
    DEBUG:INA219: read register 0x01: 0x-003 0bb11
    Shunt voltage : -0.030 mV
    Power : 0.000 mW
  • Hello Cata,
    Could you please probe the shunt and bus voltages of U2 and U4 and when you are taking these I2C readings? I can't see anything wrong yet.
    Peter Iliya
  • Hey Cata,
    Have you resolved your issue? If not, please reply back with more information. Also attach your schematics as pictures and not links to storage drive.
    Peter Iliya
  • Hello Peter,
    For the moment we fixed... we will continue with the testing phase.
    Thank you,
    Cata
