THS4521: Problem with finding components at website
Part Number: THS4521
When searching Fully-Differential amplifiers here https://www.ti.com/amplifier-circuit/op-amps/high-speed/products.html#p512=120;7000
The web-server fails to find a lot of components with  corresponding filters enabled.
For instance, in the list above, you can find THS4521, a fully-differential rail-to-rail amplifier.
But then enabling "Fully-differential" switch either in "technology" or in "feature", it will not be in the list.
Probably, there is an inconsistency in the database.
  • Hi Andrey,
    Thank you for your feedback. Although the "Fully Differential" label is present in the Part Number column, parts like this one will be filtered out when you search for "fully differential" by architecture or feature. I will look into correcting this.
    Sean
  • Hi Andrey,
    We will add "Fully Differential" to the architecture column for the THS4521. In the meantime, instead of searching under menu->Operational Amplifiers (op amps)(1472), you can go to menu->Fully Differential Amplifiers(59) to search all FDAs, including those without FDA in their architecture designation.
    Sean
  • Thank you. Let me suggest better solution for this problem:
    Just implement a text search for description field. Since there is no such option, I had to download aaalllll the list and search it manually.
