INA149: GND different
Part Number: INA149
Hi Sir
May I know INA149 could be used to measure current shut with different GND side
  • Kai,
    On dual +/-15V supplies, INA149 can support the input common-mode voltage range up to +/-275 with respect to  supply ground.  Thus, it does not matter how you call the current shunt side voltage (ground, high-side, or low-side) BUT the only thing that you must make sure of is that the voltage on either side of the shunt does NOT exceed +/-275V relative to INA149 supply ground. Even though the input common-mode voltage may be up to +/-275V, because of INA149 fixed gain of 1, the differential input voltage (voltage across the shunt resistor) must be betweeen -13.5V and +13.5V - see below.
  • Kai
    We haven't heard back from you so we assume this answered your question. If not just post another reply below.
    Dennis
  • Hi Dennis
    Thanks for your reply
