Part Number: ONET2591TA
Hi Team,
My customer and I have some questions on the ONET2591TA that I'd like to get your clarification on:
- We'd like to get a better understanding of the small signal transimpedance vs the transimpedance dependent on the average filtered bias current. How does small signal impedance change with respect to average bias current?
- We are also assuming that Figures 10,11,12 and 13 are based on small signal transimpedance. Can you please confirm that this is correct?
Tying this to example eye diagrams (Figure 12/13) is a bit more confusing since 1mAppk -> 200mVppk suggests transimpedance of 200, 2mAppk -> 200mVppk suggests transimpedance of 100. The datasheet is not clear about how the gain is limited. Is gain limiting working here? - In figuring out the differential output mVpp, does Figure 5 matter here?
Small signal transimpedance (2000~3200ohm) * modulation current (I_input 1mApp) gives 2~3.2Vpp.This looks like the work of gain limiting, but then we are having trouble understanding why it has such a wide range of 140mVpp~310mVpp as MAX diff voltage.
Mitchell
