Looking for a TIA for OC-3 rate.
Our slowest TIA's for optical communication start at 1.5 Gbps, which is much faster than OC-3. We could potentially just use a normal op-amp if that fits the requirements. What other specifications do you need?
Hi Jacob,
Thanks for your suggestion.
I think we could use an op-amp.
I will get back to you with other requirements later.
Ming
Here you go Ming, if you go the op amp route, you will want decompensated VFA, this article posted yesterday and explains all this with part tables,
https://www.planetanalog.com/author.asp?section_id=3404&doc_id=565165&
