Part Number: TL081
Hi Team, we have a customer that would like to ask the input capacitance value of TL081CP. He also wants to confirm if he could leave the offset pin floating.
We hope you could help us.
Thank you.
-Mark
Part Number: TL081
Thank you.
-Mark
Good luck Mark,
Nothing in the datasheet it seems, not sure what the model has, but if you have that up and running TINA or spice, here is an article on setting up to extract from simulation. Not sure you could trust the results unless the model was transistor level with good models.
Mark,
Based on other parts in same family as TL081, I'd expect about 6pF on each input (to ground) and 4pF between inputs. The offset pins can be left unconnected.
