Other Parts Discussed in Thread: PGA281
Team,
I am helping out with some worst case analyses and am having trouble helping spec the max and min rated voltage on the pins as well as the current. can you help me with the below?
| Description | Part Number | Package | Pins | Rated Pin Voltage (VMax) | Rated Pin Voltage (VMin) | Rated Pin Current (A) |
| IC OPAMP PGA 1 CIRCUIT 24TSSOP | PGA280AIPW | 24-TSSOP | 24 | - | - | - |
| VON: Inverting signal output | PGA280AIPW | 24-TSSOP | 1 | |||
| VOP: Noninverting signal output | PGA280AIPW | 24-TSSOP | 2 | |||
| VOCM: Input, output common-mode voltage | PGA280AIPW | 24-TSSOP | 3 | |||
| VSOP: Positive supply for output | PGA280AIPW | 24-TSSOP | 4 | |||
| VSON: Negative supply for output, AGND | PGA280AIPW | 24-TSSOP | 5 | |||
| VSP: Positive high-voltage supply | PGA280AIPW | 24-TSSOP | 6 | |||
| INP2: AUX input, noninverting | PGA280AIPW | 24-TSSOP | 7 | |||
| INN2: AUX input, inverting | PGA280AIPW | 24-TSSOP | 8 | |||
| INP1: Signal input, noninverting | PGA280AIPW | 24-TSSOP | 9 | |||
| INN1: Signal input, inverting | PGA280AIPW | 24-TSSOP | 10 | |||
| VSN: Negative high-voltage supply | PGA280AIPW | 24-TSSOP | 11 | |||
| DGND: Digital ground | PGA280AIPW | 24-TSSOP | 12 | |||
| DVDD: Digital supply | PGA280AIPW | 24-TSSOP | 13 | |||
| SDO: SPI slave data output | PGA280AIPW | 24-TSSOP | 14 | |||
| SDI: SPI slave data input | PGA280AIPW | 24-TSSOP | 15 | DVDD | 0 | |
| SCLK: SPI clock input | PGA280AIPW | 24-TSSOP | 16 | DVDD | 0 | |
| CS_N: SPI chip slect input; active low | PGA280AIPW | 24-TSSOP | 17 | DVDD | 0 | |
| GPIO6: GPIO 6, SYNC (in), OSC (out), ESC6_N | PGA280AIPW | 24-TSSOP | 18 | DVDD | 0 | |
| GPIO5: GPIO 5, BUFA (out), ECS5_N | PGA280AIPW | 24-TSSOP | 19 | DVDD | 0 | |
| GPIO4: GPIO 4, BUFT (in), ECS4_N | PGA280AIPW | 24-TSSOP | 20 | DVDD | 0 | |
| GPIO3: GPIO 3, EF (out), ECS3_N | PGA280AIPW | 24-TSSOP | 21 | DVDD | 0 | |
| GPIO2: GPIO 2, ECS2_N, MUX2 | PGA280AIPW | 24-TSSOP | 22 | DVDD | 0 | |
| GPIO1: GPIO 1, ECS1_N, MUX1 | PGA280AIPW | 24-TSSOP | 23 | DVDD | 0 | |
| GPIO0:GPIO 0, ECS0_N, MUX0 | PGA280AIPW | 24-TSSOP | 24 | DVDD | 0 |
