Automatic Gain Amplifier for Photodiode
Hello TI Team,
I am looking for I to V conversion Trans impedance Amplifier as well as one more Amplifier with Automatic Gain Control.
AGC must be able to understand voltage levels and should be able to adjust automatically to deliver fix output.
Amplifier with AGC should be able to convert minimum voltage to some fix voltage at the output with the help of AGC and also in reverse if voltage is more at input than it should reduce gain using AGC to give fix output voltage.
For Transimpedance Amplifier we will be using a Photodiode as an input which will sense intensity of light and will convert current into voltage. This voltage we need to amplify to some level using AGC.
Can you suggest such devices?
Photodiode>Transimpedance Amplifier>Amplifier with AGC>Fix Ouput(Data)
Awaiting your kind response.
Thanks.
