Because of the holidays, TI E2E™ design support forum responses will be delayed from Dec. 25 through Jan. 2. Thank you for your patience.
LM2902: Strange waveform
Part Number: LM2902
Hi Team,
I met a strange case when customer report using LM2902. I downloaded the newest model from TI.COM.
If connecting as below config, it can be seen the 10nF load shows a much slower slew rate, however if we change VBIAS 5V -> 0V, it went back to normal that is 10nF moving the fastest among 3 different loads - 10nF/100nF/1000nF, this is I think the correct result.
Any thoughts anout this strange behaviour? Thanks.
Andrew
Op-amp Stability Analysis (LM2902 - Time Domain).TSCOp-amp Stability Analysis (LM2902).TSC
