PGA280 Long Term Gain Drift
Other Parts Discussed in Thread: PGA280
I'm looking for data on the PGA280 related to long term GAIN drift.  The DS lists this for the offset but not for gain.
I see the gain error drift distribution graph but this is not quite what I'm looking for as it's not a 300hr life test similar to the testing done to get the 3.5nV/Month Vos drift number.
Any help is appreciated!
wes.
Wes Wirth
Texas Instruments - Analog Field Applications - Redmond WA
  • Hi Wes,
    The long term gain drift of the PGA280 was on the order of the test capabilities.  1 unit had a larger (0.024%) gain drift over the equivalent 10yr operation.  All other units were statistically indistinguishable from the controls.
    This would yield 2ppm/month worse case and <<1ppm/mo typical long term gain drift.  If you need more exact data please let me know.
    Viola Schaffer
  • Hi Viola,
    Thank you for the answer (Wes asked the question on my behalf.)  Can you tell me how many units were tested wtih the 10 year equivalent aging?  I am just wondering what precentage of the total sample size the one outlying unit was.  It also would be helpful to know how linear the gain drift was over time; did most of the drift happen early in the aging process or was it relatively constant throughout the test?
    Mike McFeters
  • Hi Mike,
    HTOL ran with 116 units at 150C for 300hrs.  We did have a preliminary HTOL on a previous revision (no change to resistors) on 16 additional units.  Due to logistical problems we only have pre and post stress reads for the 116 units.  We suspect that the outlier was an issue with the initial read but given that the shift was well below acceptable limits HTOL was not repeated.
    Viola
