Part Number: LM6172QML-SP
Hi guys, working with a customer on this device. Using it as a non-inverting op-amp following a DAC and R2R conversion to set a voltage level input that then feeds into a comparator. Trying to understand if we need to impedance match at the opamps inputs.
1. Is the opamp bias compensated (ie internal bias currents are well matched)?
2. Trying to understand how the input capacitance may affect the opamps bandwidth and stability. To do this could you recommend a value to use for input capacitance (CM and DM) of the opamp?
