Adding offset to output in a cascade topology
Hello All,
  • I am wondering why some people prefer to add the offset to the second stage of the cascade opamps when they want to support bipolar differential inputs. I heard something about input balance in differential analog measurements. in this way, a negative supply is needed to pass the negative inputs from the first stage. (topology 1 )
  • We usually add offset to the positive input of an opamp to shift the voltage from negative range, hence we can support bipolar differential analog inputs with a single supply opamp. (topology 2)
Could you please let me know if these assumptions are correct and which one is the best regarding the quality of measurements.
Mehri
