Original details: On a properly functioning circuit measuring from either the LoadCell In- or the LoadCell In+ to ground with no power applied will result in a reading of 75K ohm. On a failed circuit the measurements results in a reading of 56K ohm. On a properly functioning circuit with LoadCell In- and LoadCell In+ open and power applied the output at TP04 is 0 VDC. On the failed circuit the output is approximately 2.3 VDC. Please help me understand what could cause these results. Thank you.
