Part Number: INA230
Although the INA230 does allow for negative differential voltages on its analog inputs, it doesn't allow for negative common mode voltages (something that is pretty commonly seen in the automotive environment). It is easy enough to protect the 3.3V power bus from these voltages. But what is the best way to protect the analog inputs? Could I use a low-side blocking diode - would the floating reference cause issues for the sensor? What about blocking diodes between the analog sensor inputs and the sense resistor - wouldn't the diode drop across the inputs be more problematic than the floating reference?
-paul
